3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Vrayhairmtl not working in max
1 REPLY 1
charlyoreil
296 Views, 1 Reply
So im trying to add some hair to my model using hair and fur and splines. I have mr prim enabled in environment and effects. When i dont use the mr prim on the hair and fur modifier itself im able to change the colours using the hair and fur modifier and it works okay juat the quality is pretty bad in render. When I use the vray hair material in mr prim though, the hair goes dark and the vray material doesnt change anything no matter what preset I select, blonde or brown etc. Just the same dark brown colour. Its like the vrayhairmtl isnt working. This is in 3dsmax 2017. Not sure how well I explained this. But does anyone know if im doing something wrong. Thanks
1 REPLY 1
rendermaster
in reply to: charlyoreil
can you elaborate more....its a little bit confusing. perhaps some snap shots will be fine. what render engine you are using...vray mat will not work on mental ray
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
