VRay Rendering problems
Hi, When I am using Default rendering its coming perfect but when I am using vray its coming black also one rendering dialogue box is poping out which showing long process...Can anyone help me on this?
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Could you check your V-Ray camera settings? Is this a physical camera? Check your camera's exposure and shutter speed settings. Also try placing your lights with V-Ray sun or adjust the angle. There are several V-ray lighting options, you might want to override the Max environment with the V-ray GI Skylight override. Also make sure that your F-stop is not too high.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
HI Matt,
Thanks for your reply. Now I have removed the camera but still its not showing the proper render. I have attached 3 screenshots which include my vray setting and final render. I am still getting one rendering dialog box which showing me the rendering process. I have not used any material and lighting but still its showing a long process.
Please help me on this issue.
Abhishek
kgokhangurbuz
Hello;
I just downloaded your scene and it's opened just like this:
And it's rendered like this:
I did not do any changes, even not a viewport change but just hit Render button. (My V-Ray version is 3.4)
After this, i checked your faces if they are flipped and they are just fine. But one thing i just noticed, you have applied standard material to your objects and your render engine is V-Ray.
V-Ray can and will be rendering standard materials, but the chances of rendering artifacts are possible and standard materials take more time while they are being rendered with V-Ray.
Can you please assign a VRayMTL to your objects, place a V-Ray Light source (just place a VRayLight > Type: Dome (for this scene) in top or perspective viewport (it doesnt matter where it's placed, just create one anywhere in your scene) and re-render and please share your result.
Regards;
