VRAY Gpu render
VRAY Gpu render
antoine_viala2
VRAY Gpu render
antoine_viala2
I just started using GPU rendering on 3dsmax. I have a size problem.
As you can see on the attached video, during the calculation of the light cache the colors, reflections and lights work very well but as soon as the rendering of the image begins, everything disappears and the image becomes flat and without relief.
Could someone enlighten me (it's the case to say).
Many thanks in advance,
https://drive.google.com/file/d/1dlZ...ew?usp=sharing
RobH2
It's likely that GPU render does not support the transparency or kind of transparency the leaves use. Have you rendered a normal V-Ray render? And if you do and it looks right, then you'll know that GPU is not supporting your transparency. GPU renders don't support everything. Look here for more on that:  https://docs.chaos.com/display/VMAX/V-Ray+GPU+Supported+Features
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
kibrituss
it seams you are missing translucency map on your material editor.
check the leave material which must be looks like above picture.
thus it will work ensure....
Sincerely
Huseyin Durak
Kibrit Creative Solutions
Cloud Render Farm
