What wrong with my setting? Why is so bright? Render the same
I'm working in 3ds max 2017, and use v-ray 3.4
This house I've imported from Revit as fbx file.
In attachment I send screen shot and also send link to my file (http://file.sampo.ru/rgnvt3/)
Thank you in advance
I'm not sure how Vray integrates with 'Envionment and Exposure' controls [Number 8 on the keyboard], but with most other rendering engines the user need to set the values correctly.
With iRay I use mr Photographic Exposure, and set it to around 13 for interior renderings.
http://help.autodesk.com/view/3DSMAX/2017/ENU/?guid=GUID-E1A6D466-CABB-4C8A-97A9-0C191C69F9BD
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Number 8 on key board, then select Vray Exposure Control.. however you need to understand first a lot...ISO, FSTOP, Shutter speed etch...
check and consult vray manual: https://docs.chaosgroup.com/display/VRAY3MAX/V-Ray+for+3ds+Max+Help
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
