V-ray Material transition isn't smooth?
Hi there,
I am trying to render a ps4 controller in a 24k gold version but I'm having a problem.
In the image above I've marked 2 red squares in which the material transition isn't as smooth as I hoped for.
The green square shows the same material but in the way I want to.
I can't figure out what settings are causing this problem, I've tried the following things without any success;
  • Change the lighting.
  • Change the environment.
  • Lowering the material glossiness solves the problem but changes the '24k' look too much.
  • The model is perfectly smooth so that shouldn't be the problem as well.
In the appendix I've added the material file, make sure to use ORO_gamma_2.2.
Thanks in advance! :3
Something went wrong with the file upload, it should be linked to this reply now.
