3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
UV map doesn’t export from 3ds Max to .fbx to Substance Painter.
3 REPLIES 3
harriet8GAP7
880 Views, 3 Replies
Hi, as you can see from my screen shots below I have done a UV unwrap in 3ds Max and I have exported to .fbx and imported that to Substance Painter. Can anyone please advise why my UV map is exporting like this, and not like the one I created? I suspect that this is the default auto unwrap from Max, not my unwrap. I know that the problem originates in Max not in Substance Painter because I have also checked the .fbx by bringing it into Maya where it also has the same problem.
3 REPLIES 3
Seems an issue with the Skin modifier. The solution I found was to duplicate the geometry, collapse it to an edit poly, copy the UVW from the other geo and export.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Thanks, I appreciate your investigative work! I ended up redoing the UV map in Maya, but it sounds like I could have used your solution instead.
No worries.
Ciro Cardoso
