Two Split render image in vray frame buffer
shinyee
shinyee
Hi, I have encountered a problem with rendering. While rendering the image split in two in one frame buffer. No sure is the camera or vray problems.
I have try render without camera but still it will split.
Does anyone know how to solve it? 😭Thanks.
Francisco_Penaloza
did you add the stereo camera helper in your scene by mistake??
this gizmo looks like the regular camera icon.
delete it and then place a physical camera
shinyee
Hi, thanks for the reply.
I had deleted the camera but still doesn't work.
So, I just open a new file and copy the model over. It temporary solved the problem  but still need to seek solution in case it happens again.
XR3D
Thanks @Anonymous.penoloza This fixed an issue one of my guys was having!!
rendermaster
If you have vray dome camera in your scene, delete it.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
