Translation problem
Good morning all,
I have a strange problem in 3ds Max 2017.
When I move an item in the viewport, instead of moving smoothly, it jerks.
It is not a display problem but a translation problem. The object jumps regularly as if there is a displacement constraint every x centimeters.
I have a problem with the animations and I have the impression that it is linked ... I animated a rotating planet (while in the viewport the rotation is going well ...) and the rendering the different layers (Earth, atmosphere, clouds) do not behave in the same way.
I am attaching 2 images to you where we can clearly see the collisions and the atmosphere which moves. While they all have the same pivot.
Thanks for your help.
