Message 1 of 1
Tiling UVs show black border across faces in 2048x1024 texture?
For some reason, 3DS Max is showing a vertical black border between the edges of each face. This isn't present in RizomUV:
In 3DS Max after using UVW XForm to set U Tile to 0.5
View in RizomUV before export
I suspect this is because of hacing to use the UVW Xform modifier to display the UVs properly with a rectangle texture map. Unfortunately that is the largest supported resolution by the game engine, so I can't use different dimensions. Is there a better way to go about this?
