3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Thinkbox Deadline color management OFF
6 REPLIES 6
osukas
781 Views, 6 Replies
I know that Thinkbox Deadline isnt a Autodesk product, but asking here if someone had the same issue
Im working in 3dsMax 2024 with OCIO activated, ACEScg, when I render the sequences in my PC the colors are Ok, but I do the Network rendering using Deadline, the colors are different. I noticed that in the Render window is a message: "Color mgmt OFF"
even when I assign the PC where the project was made to be the only machine in the TASK, it turns off the OCIO config, and the colors are wrong. Someone had this issue before with the plugin?
Labels (2)
6 REPLIES 6
RobH2
in reply to: osukas
I haven't used Thinkbox Deadline in a few years but when I did I seem to recall they had a pretty robust forum. Have you posted there? You might find more help on that forum.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
osukas
in reply to: RobH2
I posted in the AWS forums, no answer yet.
If I get some usefull info there I will share it here.
hodol1735
in reply to: osukas
I am also experiencing the same issue. If anyone has resolved this problem, please share it.
osukas
in reply to: osukas
I still cant figure out how to fix this. :downcast_face_with_sweat:
a temporary fix is I rendered a color checker card in local and one in farm. Then the comper in Nuke made a node to grade the color.
MartinBeh
in reply to: osukas
Is this of any use?
https://forums.thinkboxsoftware.com/t/color-management-off-while-rendering-with-3dsmax-with-ocio/318...
Martin Breidt
http://scripts.breidt.net
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
osukas
in reply to: osukas
I made more tests and Deadline is ignoring the OCIO configuration. In my scene I removed the OCIO (Color Management: Unmanaged) and when is deactivated looks like the render in Deadline, but I need it to work so I can have my colors right.
I have a temporal fix, that is generating .tx textures. Then I edit the names to remove the colro space info, so my texture instead of being diffuse_sRGB_ACEScg.png.tx is diffuse.tx
but is a lot of extra work specially when you have 90 textures in scene
