3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Slate color coding question and atypical multiple material workflow question
0 ANTWORTEN 0
Nachricht 1 von 1
RobH2
194 Aufrufe, 0 Antworten
I work alone so it's likely I'm not up to date on some creative studio workflows.
I've been given a file. It has a single object that's to be rendered with 9 different materials. Normally, you'd use a 'Multi/Sub-object' and just change the MatID and render.
1) This studio uses a VRayBlendMtl and Coats. Is this a new and better workflow? I can't figure out what's intended. If I turn "OFF" all the Coats that I don't want, I still don't get the material I leave checked (also leaving the Base checked too).  See #4 in my screenshot.
2) I'm surprised I don't know this and I can't find documentation. When there is 'RED' in a material I thought it meant an 'Incompatible' material (see #1). But, in #2, it's a normal and common Chrome VrayMtl. But then in #3, there is a 'RED' box around the swatch. What is that RED Swatch indicating?
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
0 ANTWORTEN 0
