3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Rendering Vertices
8 REPLIES 8
Message 1 of 9
1234 Views, 8 Replies
Rendering Vertices
What's the best way to render only the vertices of an object? I also need them to be shaded with the light in my scene.
D
8 REPLIES 8
Message 2 of 9
CAMedeck
Check out the Lattice modifier. You can turn off Struts and only have Joints remain. The Lattice modifier turns visible edges and vertices into geometry.
Be very careful if your geometry is complex!
Chris Medeck
Message 3 of 9
Another way is using the Scatter Compound object.
Convert to Editable Poly and delete the Distribution object.
(See Attachment.)
You must be very careful by this method as well. 🙂
Edit: In case you are not familiar with the Scatter object; Create a small sphere, activate the Scatter press on the “Pick Distribution Object” hit the object having the vertices you want to render, the next operations are clear I think.
ivan
Message 4 of 9
I'm going to have millions of verts to render........ So, I'm not sure these are the right methods..... I know in Lightwave you can create a vertex or a bunch of them and render it....... Super simple...
Message 5 of 9
If there are millions of them, you will not be able to see all of them „shaded with the light of your scene” just in one rendered image, I’m afraid.
If you want to produce a kind of Points Cloud file you need software able to do it.
One possible option will be to export the mesh into Lightwave
and render the image you are after.
Sorry I don’t know a way to achieve this in Max.
Message 6 of 9
Another method is to use Pflow with an Object Position opperator, set to vertices. Then each vert is a particle.
Message 7 of 9
(See Attachment.)
ivan
A small but important modification would be using MR proxies instead spheres to reduce RAM consumption if a million vertices have to be rendered.
Message 8 of 9
That’s right; I didn’t know he is having a millions of them; in his first post he was after a method to render only the vertices of undefined object, “shaded with the light in his scene”.
Message 9 of 9
nullmorpheme
Try to use Tyflow
