Rendering Issues
Rendering Issues
Rendering Issues
Hi there,
im having issues with rendering one of my walls/objects. As you can see from the photos below its clearly there within the normal viewport and then it isnt in the rendered view. i havent added anything other than all textures, lighting, objects and 1 camera into this.
So, how can i change and sort this to make it appear in the rendered preview? cause i have no idea how.
Thank you
Regards
Sarah
rendermaster
try / check this.
right click on that object and select object properties. under object properties, tick on renderable.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
hi there, I have tired that and it rather annoyingly it says that is it enabled. although I have just managed it by flipping the polygons.
thank you for your help and for getting back to me 🙂
