3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Rendering doesn't show UVW maps
1 REPLY 1
Szigeti.Eduard
123 Views, 1 Reply
Hi ,
I have a model that looks exactly what I wanted in the viewport, but when rendering is completely different. None of the modifiers are showing in the render.
If anyone could help, please see attached the model and the rendered image.
1 REPLY 1
RobH2
in reply to: Szigeti.Eduard
You didn't provide the texture maps so opening the Max file is not as useful as it could be. However, I don't see any UVW modifiers on your door. If I put an 'Unwrap UVW' modifier on it and check it, it doesn't appear if it has any proper UVs assigned.
I've attached a file with UVs on it. As you can see, the viewport matches the render.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
