Rendered objects don't match position.
Rafamacamp
Rafamacamp
I think that the umage explains itself.
I'm using AMD Fire Renderer. So, any ideas?
rendermaster
is it animated?
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Rafamacamp
No. Still in modelling process, so it's single frame.
PROH
Hi. The renderer doesn't render the whole viewport, but only the part that fits into the specified render ratio. If you want to see in the viewport what's rendered, then turn on "Show safeframe" in viewport configuration.
Hope it help
Edit: Another possible reason for this, could be that the renderer isn't set to something else than "view" (for example "blow up"). So check this in the render settings.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Rafamacamp
My question is about that knee. You can clearlly see that is not in the right place in the render.
Plus: I figured that is Fire Renderer fault, Mental ray did it correctly.
Thanks any ways.
PROH
Ahhh... didn't catch that. Glad you found out what was happening 🙂
3dsMax 4.2 to 2018
