Hey Guys,
I have a BIG problem with the look of my render.
One day, when I tried to render my scene - it looked completely different from my viewport. I mean, objects were disoriented and I can't even see all the objects in the scene (on render).
It happens if I render it, with Vray camera, Mental ray, or even if I render a scene without the camera.
So, I guess It has a bug.
I changed Windows, uninstalled 3dsMax - It still happens.
I'll attach a photo of a basic example of the case.
If U know what's wrong with this, PLEASE write!!!
Thank You,
Milana
I don't know why the one wall appears to move. It would help to have a copy of the file.
You might start by right-clicking Perspective in the viewport window and selecting Show Safe Frames to ensure that the aspect ratio of the viewport and render window are the same.
Did all of that - still the same problem appears.
I'm starting to think that maybe I have bad version of Max or Vray plug- in...I just can't figure It out..
anyway, thank You for trying to help 🙂
This looks vaguely familiar to another topic I saw recently. The viewport looks fine, but some objects render as if they were located at the origin... I'll look around and see if I can find it again. That guy had a couple boxes and a teapot, and was just trying out V-Ray.
Chris Medeck
render doesn't match the viewport
This problem is only come when you used frame buffer or this problem is come into default 3Ds Max rendering window??
Thank you,
hp
A student in the school I teach is having the same problem, and we havent't been able to find a solution. 3ds Max 2016 with Vray, the problem happens even with scanline or mental ray. If someone finds a solution please post! Thanks!
I unlocked the "View to Render" and everything works fine now.
