Alright so i have a problem, i want to remove materials/shaders/texture enteirly from my 3ds max scene.
I have tried looking at a bunch of different forums but i cant seem to find any option i 3ds max or method even, can it really be true there is no way to remove materials,shader and textures from a scene.
(Normally i use Maya, and in there is a button called 'delete all unused nodes' this entirly cleans the scene from unused nodes).
Best Regards
Solved by darawork. Go to Solution.
via MaxScript Listener window simply type:
$*.material = undefined
After you type that script, extract and run this .MCR script from the Scripting drop-down Menu -> Run Script...
http://www.digitalanimation.net/maxscripts/DAS_PurgeUnusedMaterials1.1.zip
Right-click the toolbar -> Customise...
Then browse to the Toolbars Tab, Group 'Main UI', Category 'DAS Tools' and from the Action list click and drag 'DAS Purge Materials' to a free slot on any toolbar on the screen.
Now: Open the Slate Material Editor or The Compact Material Editor and then Click the new button on the toolbar.
Be careful, as this script will delete all materials from your Editor... even used ones (I just tested it myself).
To check that it has worked: Click the [MAX] file menu button -> References -> Asset Tracking -> File -> Refresh
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
This is ridiculous. U know how to delete materials in blender? Ctrl + A + Delete. Why is 3DS Max so overcomplicated?
To remove an already assigned material in 3ds max:
Is there a way to remove an unassigned material?
I have a material that is giving me problems in the Arnold renderer. It's not used by any objects in the scene. I can see it in the Material Editor, but clicking Delete does not remove it, neither do the various scripts. Is there no way to remove it?
A material in SME doesn’t mean it’s used in the scene, and vice versa. It can be deleted in SME, but still used in the scene.
There’s an option in SME to select objects based on the material. That is a starting point to see if it’s still used.
Then, a map/material can be used in modifiers, like Displace or H&F, or in places like Environment Map or Lights.
It’s also possible to “flush the cache” with Main Menu>Arnold, to release all maps in memory.
To get rid of an unused material in the regular MaterialEditor you can just replace it with another one (loading a fresh material or drag&drop another one onto that slot). In SlateMaterialEditor just delete it from the canvas.
To get rid of unused bitmaps open File-->Reference-->AssetTrackingToggle and click on Refresh (the left button) - this should force a new indexing and flush unnecessary stuff from the scene.
Just putting in some additional input, and yet another call out for the Devs to work on an in-software 'Purge' routine in 3DSMax. At the end of the day .Max files are databases of code. A few simple crosschecks internally in the software would throw up truncated materials, xrefs, plugins, pathways, materials and other junk (animation tracks, unnecessary modifier stack history). Either you love the code, or not. AutoCad has it. I don't want to be relying on 3rd party 'Cleaner' utilities, and scripts to try and keep the basic scene size to the bare minimum. Disk space may be cheap, but that is not a solution. Teague Scene Checker by Colin Senner and Forensic by Sinisoftware are some solutions that should be integrated into 3DSmax by default. They are screaming out to be integrated.
https://forums.autodesk.com/t5/3ds-max-ideas/3d-max-heavy-files-purge/idi-p/7049422
Darawork
AutoDesk User
Nobody have problems with unused scene materials - so all help suggestions are wrong or unnecessary.
"Purge material" script = Ctrl+A+Delete or Edit-> Clear View
Asset Tracking Refreshing - No comment on that!
If want to keep the scene size to the minimum don't delete "unnecessary modifier stack history"
As for scripting - "Things" from Max getting exposed to Maxscript - not other way around...
3DSMax needs a purge routine.
Darawork
AutoDesk User
Make a simple test in fresh scene:
-Create some primitive obj. like teapot - Save scene (SS)
-Add Edit Poly modifier -(SS)
-Collapse the stack (to Editable Poly)-(SS)
Now something more serious, clear scene:
-Create 10 teapots - Save scene (SS)
-Select all, add TurboSmooth modifier (2-3 iterations) -(SS)
-Collapse the stack (convert all to Editable Poly)-(SS)
After every scene save(SS) look at the scene file size...
Surprise!? But shouldn't be, reason is pretty simple, same for all "computer" files size.
Harder to understand is why is that "collapsing" workflow officially recommended.
And there is no benefit from it in any field.
Interesting alright, I generally do collapse models before rendering, and attach all objects with a similar material. There is no doubt that this will speed up viewport fps and rendering time in my case. Corona render suggests that users do it as a means of scene optimization. There is also some interesting information here:
https://garagefarm.net/blog/guide-to-rendering-optimizing-scenes-in-3ds-max-through-geometry
And in this Autodesk Knowledge article:
Scene optimisation is always worth discussing. 🙂
Darawork
AutoDesk User
