Point Cloud Render Shape
Hello, I am converting 3D meshes into point clouds and then using the Arnold render to render them. I would like to create an animation fly-through of these renders. The renderer creates the point cloud as circular colors. I was hoping to render these points as squares or cubes (This is an art project).
Is this possible in Arnold or could you point me in the right direction?
BenBisares
Autodesk Support
Autodesk Support
What are you using to convert your 3D meshes to point clouds?
Just thinking out loud but if it was possible to convert your mesh into a particle system it would open up more possibilities. For example each particle could be replaced with a camera facing 2D shape that can have a material applied. You can do all sorts of things with that.
As is stands I'm unaware of a way to have Arnold render the individual points in a point cloud as a different shape but someone better versed in Arnold than me may know of a way.
Ben Bisares
