@alikarabuk523 Does Vray support standard Max lights, Omni in this case?
- Arnold does not.
In the event that it's not simply an issue with the Omni light's properties (e.g. Light Strength), then you will have to use Vray lights instead. You can replace your existing Omni lights with Vray lights by doing this
Your omni lights should now be replaced with your VRayOmni light. I did not author the code
Thor Nielsen
3D Generalist // 3ds Max userCan't find what you're looking for? Ask the community or share your knowledge.
