3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
omni light dosnt shown inn the render
2 REPLIES 2
alikarabuk523
550 Views, 2 Replies
Tags (1)
Labels (1)
2 REPLIES 2
thor98_
in reply to: alikarabuk523
@alikarabuk523 Does Vray support standard Max lights, Omni in this case? :thinking_face: - Arnold does not.
In the event that it's not simply an issue with the Omni light's properties (e.g. Light Strength), then you will have to use Vray lights instead. You can replace your existing Omni lights with Vray lights by doing this
  1. create a Vray point light, name it VRayOmni
  2. open maxscript listener
  3. select all of your omni lights
  4. in maxscript listener, insert this code and hit SHIFT ENTER
    for obj in selection do instancereplace obj $VRayOmni
Your omni lights should now be replaced with your VRayOmni light. I did not author the code
Thor Nielsen
3D Generalist // 3ds Max user
newtovray
in reply to: thor98_
Where may I find the Vray point light in 3DS max?
