Objects appear dark when rendering
Greetings. I would like to know why when rendering an object, without assigning material, it goes dark and others do not. It seems strange to me. I re-model the same object and when rendering, it comes out again dark. Is the computer virus? Or if not, how do I solve it?
irishman_team_kilber
what type of light are you using? that is normal if you have only one light in the scene and they are far apart it you add another light in your to the LT of the box then they should both be lit you mite get an overexposure go you would need to decrese the second light multiplier for example or you can use the exclude button and exclude the second object from shining on the first
Richard.Vivanco
Assign a shell modifier to the left object and try again.
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Youtube | LinkedIn
autodesk 3DS pro
Thank you very much
