noise map phase cycles
carlwellander
carlwellander
Can someone verify that when using "phase" in a Noise texture and animate it from 0 to 10 over 100 frames you get 10 cycles that will show 10 pulsing patterns?
It looks as if the pattern comes an goes.
The attached file has a phase that runs from 0-130 hence the lesser number of cycles.
Is there a way to modify the noice pattern over time without these in the face cycles?
MartinBeh
Just curious: What made you expect the noise map phase to cycle once between 0 to 10?
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
carlwellander
I was probably unclear about my problem. I'm asking why the "phase" doesn't just change the pattern in a random way over time?
And that change to be without having a base line on each integer that shows in render as a pulsing pattern.
MartinBeh
Not sure I fully understand yet, but maybe animating the 3D world position of a UVW Map perpendicular to your mapped plane would give you what you want?
carlwellander
I removed the phase. If I offset the coordinates in x or y, then the noise pattern slides along the surface as expected. But if I offset z I get the fading in and out effect. The pattern never goes away but it intisifies and fades in cycles no matter how small a value I assign to z.
I'm starting to thinkt that this is the nature of Max noise and I'll have to look for a different texture.
MartinBeh
Is this what you want?
(view in My Videos)
carlwellander
Thanks  MartinBeh but. It looks ok when I focus on one specific area but when you look at the big picture you can see the pulsing effect. About 8 of them in the short time span of the animation. Now I decided to change my entire approach and use a PhoenixFD sim. Thanks again for your effort.
