No Indirect Illumination menu on the vray render setup?
不适用
4,496 次查看
2 条回复
1 条消息(共 3 条)
不适用
0 个赞
已接受的解答 (1)
4,497 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
darawork
已接受的解答
Same here:
The Indirect Illumination settings are under the GI tab in later versions of vRay;
Here is what it looked like in older versions of vRay (from 2011):
You may want to update to the latest version. vRay 3.6 is out now (and 3DSMax 2018 too btw).
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
0 个赞
3 条消息(共 3 条)
不适用
Hi, i'm new to 3d max therefore not very sure of how thing works.
im having a problem with the render setup after i downloaded the 3.60.04 vray trial. under 'render', 'render set up', my 'GI' as well as 'settings' tabs are empty which is not suppose to be the case. may i know whats the problem of this? thank you
0 个赞
