Need Help | 3Ds Max 2017 | Normal Map issues with Physical Materials | Vray|
Hello Everyone,
I'm new Here. 🙂
I'm rendering car interior, I'm using Physical Material with V-ray Render.
Put a HDRI in Environment also in Environment and Reflation Environment slot in Render Setup.
I used Diffuse, Roughness, Normal map (via V-ray Normal). Gamma override 1.0 for roughness and Normal maps.
I did Textured it in Substance Painter and using Exported Maps.
This Problem occurs in render also.
I have attached material preview and render in attachment.
Please Check it.
Thanks in Advance 🙂
Francisco_Penaloza
Is there any reason why you are suing Physical material instead of VRay material??
They using VRay material and let us know if the problem persists.
Thanks for your Reply 🙂
I watched a tutorial on YT here is link (https://www.youtube.com/watch?v=82hhg8Q1nus).
He is using 3Ds Max 2019,Arnold render and physics materials to get realistic effect with maps.
So i tried to use it with V-ray.
I texture model in Substance painter, so after exporting maps, i don't want to go any long process.
Just apply maps in physics material and render it. That's why i used Physics materials.
Pleas guide and suggest me other ideas or how to properly use Physics materials, V-ray and others.
In the V-ray materials i can't get idea where to and how to proper put maps.
I know Diffuse, normal, Height, Roughness goes in V-ray Material Slots, Confused for metallic.
I put maps directly into the slots, if i doing something wrong or something i don't know, please guide me.
Thanks 🙂
