3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
motionvector Arnold AOV is all black
7 REPLIES 7
Message 1 of 8
osukas
1326 Views, 7 Replies
Hello, Im new to Arnold and Im learning how to use AOVs
Im trying to get the motionvector pass, but is all in Black. I tried to move the exposure but is still empty.
There is a step im missing here?
Labels (2)
7 REPLIES 7
Message 2 of 8
CiroCardoso3v
in reply to: osukas
I believe there is a bug. Jump to Arnold Answers to report it, as there you have direct contact with the Devs. I also need the motion vector working.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 3 of 8
Yes, bug.
If I create a custom AOV, rename it to motionvector, set the type to RGB, and the filter to closest, I get motionvectors.
// Stephen Blair
// Arnold Renderer Support
Message 4 of 8
Thank you for the temporary solution, Stephen.
Although I need to test it in Nuke, as the tool will read vectors to create the motion blur.
Ciro Cardoso
Message 5 of 8
osukas
in reply to: osukas
Is working, Im seeing motion vector data. THANKS!
There is a way to have the motionvector data without having motion blur in the render?
In my PhysCamera I have to activate the motion blur to see it on the motionvector AOV, if I deactivate it, is all black
There is a way of getting your render with no motion blur but still getting motionvector data?
For the moment im reducing the shutter to 0.01
Message 6 of 8
CiroCardoso3v
in reply to: osukas
On Diagnostics tab you can ignore motion. Never tried that, but I would start there. Also I am not sure if you need to have motion blur on the camera for the AOV to work. I guess that is the point of the motionvector, to avoid having to calculate motion blur.
Ciro Cardoso
Message 7 of 8
osukas
in reply to: CiroCardoso3v
It Worked!
THANKS!
Message 8 of 8
teamSP26J
in reply to: Stephen.Blair
This cannot be real that I get this same bug in end of 2023 ..
Thanks for the solution but this is really sad.
