motionvector Arnold AOV is all black
osukas
osukas
Hello, Im new to Arnold and Im learning how to use AOVs
Im trying to get the motionvector pass, but is all in Black. I tried to move the exposure but is still empty.
There is a step im missing here?
Replies (7)
CiroCardoso3v
I believe there is a bug. Jump to Arnold Answers to report it, as there you have direct contact with the Devs. I also need the motion vector working.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Stephen.Blair
Yes, bug.
If I create a custom AOV, rename it to motionvector, set the type to RGB, and the filter to closest, I get motionvectors.
// Stephen Blair
// Arnold Renderer Support
CiroCardoso3v
Thank you for the temporary solution, Stephen.
Although I need to test it in Nuke, as the tool will read vectors to create the motion blur.
Ciro Cardoso
osukas
Is working, Im seeing motion vector data. THANKS!
There is a way to have the motionvector data without having motion blur in the render?
In my PhysCamera I have to activate the motion blur to see it on the motionvector AOV, if I deactivate it, is all black
There is a way of getting your render with no motion blur but still getting motionvector data?
For the moment im reducing the shutter to 0.01
CiroCardoso3v
On Diagnostics tab you can ignore motion. Never tried that, but I would start there. Also I am not sure if you need to have motion blur on the camera for the AOV to work. I guess that is the point of the motionvector, to avoid having to calculate motion blur.
Ciro Cardoso
osukas
It Worked!
THANKS!
teamSP26J
This cannot be real that I get this same bug in end of 2023 ..
Thanks for the solution but this is really sad.
