3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Missing Maps when importing fbx file from REVIT
3 REPLIES 3
jason_spiller
745 Views, 3 Replies
Hi
I have exported a model from REVIT 2013 to Max Design 2014  - no problem. However, wjilst all of the materials have been exported into the scene all of the maps appear to have disappeared. any suggestions as to why - or if not where can I find them? I have spent a good 30 mins looking all over my system and cannot ocate these maps!
Thanks in advance.
3 REPLIES 3
PROH
in reply to: jason_spiller
Hi. This is a known problem with fbx export from Revit. Since the problem lies in Revit, you might get more help in a Revit forum.
Does the problem also occur when using Autodesk Materials?
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
jason_spiller
in reply to: PROH
It only occurs whe importing from revit - any files created in max have no issue with missing maps.
PROH
Yes, exactly. The problem lies in Revits fbx exporter, not in Max. What happens if you import a RVT-file?
For a solution on the fbx export, you should try a Revit Forum - someone must have found a workaround.
3dsMax 4.2 to 2018
