I'm using the shader "Car Paint" with the Mental Ray render and trying to make a car in black but even putting a black color in the "Base Color", the render always appears in a shade of gray.
I accept suggestions.
thank you
thank you
Maybe it's flakes colour or other colour settings ?
Can you post ZIP-ed scene with your material assigned to sphere ??
I tried several settings including the flakes but it did not work. I put the original scene attached
I´m using 3ds max 2014
Thanks Kcpr!
Thanks Kcpr!
OK, I've played a little with settings, and your car is now black 😉
I've attached the scene and posting the screen for you to know which settings affects colour and reflections mostly.
Very very thanks kcpr!
And u have a nice site. I liked the sss shader for iray. So good!
Marcelo
Marcelo
Hey guys, very interesting Topic.
I tried to play with your car scene myself, but i only got Max 2012, so I couldnt open it.
Marcelo, if you have time do you think you could export it in a 3ds max 2012 Version again?
ty
Criss
ty
Criss
Hi Criss
I put a scene saved in max/2012 ok.
Marcelo
Hi Criss
Marcelo
nice marcelo! thank you very much.
for some strange reason, it crashes very often while rendering. but its an interesting file.
cheers
cheers
