Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Map with Alpha channel in Arnold
2 REPLIES 2
ingmar.wittmann
4360 Views, 2 Replies
I want to use a decal map with alpha channel on my physical material with Arnold.
In Mental Ray i did this with the  mix map and the alpha channel in the mix channel.
The old mix map is gone. The new arnold RGBA mix map doesnt not get the alpha channel from the old bitmap map parameters.
It works when i extract the alpha channel and use it as a normal black/white image in the mix channel. It´s not working with a rgba image in the mix channel and select to use alpha only.
PS: Where is the composite map?
2 REPLIES 2
ACCCC
in reply to: ingmar.wittmann
Not sure what you mean, it works fine for me, diffuse = input 1, decal diffuse = input 2 and a copy of your decal diffuse set to Alpha as Gray in the mix channel
ingmar.wittmann
in reply to: ACCCC
sorry, it works , i missed to check alpha as greySmiley Sad
