Announcements
Is the purpose of Distributed Rendering to replace Network Render?
Haider_of_Sweden
Haider_of_Sweden
Is Distributed Rendering replacing Network Render or are people using both of them?
Are there pros / cons in either of them or is Distributed Rendering the new technique to be used?
Haider_of_Sweden
Apparently, I was mixing things together.
"Distributed  Rendering" exists only for Vray and is therefore irrelevant in general 3dsMax terms.
BenBisares
Autodesk Support
Autodesk Support
I know you marked it as solved but just to add some information, distributed rendering in general is a way to have multiple computers render a single image. This is done by distributing the individual buckets to each render node.
In broad terms, network rendering sends different images to each render node which won't really make things faster if you're just rendering one image.
Ben Bisares
Haider_of_Sweden
Thanks for adding clarity to the matter.
But does it mean the feature "distributed rendering" exists for other renderers than Vray e.g Arnold?
BenBisares
Autodesk Support
Autodesk Support
Mental ray had this feature but Arnold does not has this feature natively as far as I'm aware.
Ben Bisares
CiroCardoso3v
You can get something like that with AWS Deadline
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
