Import igs format not showing shaded material in viewport and not rendering
09:53 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hello, i just started working in vray and i have a problem that i am not able to figure it out.
i import a 3d file from solidworks and after importing i try to add material, but when added on object and activate shaded material in viewport , the material dosn't show like it should. it has a plane color.
when i apply the same material on an 3ds max box for example it work perfeclty. the same thing is when i try to render, on the object imported no material just plane color,on the object created inside 3ds material applied perfectly. What can the problem be, and how to fix it? i try chageing display drivers, toggle material color with display color no success.
Link copied
