Image I/O Error -- V-Ray Error writing out .exr sequence
Message 1 of 1
Using VRay 3.4 Edu for 3ds Max
I am attempting to render out an OpenEXR sequence in Max. Each image renders well without problems, but I am prompted with an error message saying that certain files will not write to the folder that I have specified in the Save File option.
The message I am getting is stating that an 'alpha', and then 'RGB_color' can't write. Image I/O Error. As I click through Cancel and then Cancel, the .exr file will then save in the specified folder after finally prompting me with 'V-Ray Error, there were errors writing to output'. But I am rendering a sequence which will take 8 errors, I will not sit and click through these errors for all of the 240 frames.
I did use the Resource Collector to render on a different computer, potentially an issue there. In the resource collector I brought over all of the texture maps, the 3ds max file, and the HDRI for rendering. The VRay renderer native to the file is Adv 3.6.
Appreciate help in advance!
Replies (0)
