I can't suppress a material nor a node in the editor, once it has been created impossible to delete it from the editor
Which editor are you using, Slate Material Editor or Compact Material Editor?
Does this happen in every file, or is it just one file with the problem?
Chris Medeck
Hi, I use Slate and found no solution for it. I just upgraded 3dsmax 2024 1.0 to 3dsmax 2024 2.5 and everything came back to normal.
if you add an image or video related to your problem, it will be more descriptive so that we can offer a solution.
Enjoy your work.
