How to Render a Model in Wireframe?
Message 1 of 9
I have an assignment due tomorrow...lol and am having difficulties rendering my object in wireframe.  I am using 3ds Max 2022 version and I can not find the 'Shader Basic Parameters' rollout in my  Material Editor as I have seen on other Youtube videos.  How do I render my model in Wireframe?
Replies (8)
Message 2 of 9
james.parker.37.ctr
I'm assuming you are using Arnold. You can search for the material in the search box. Also make sure you renderer is set to Arnold.
This a good you tube video https://www.youtube.com/watch?v=sjfx9l6kqEI
Message 3 of 9
rendermaster
Under Shader and Basic Parameters, tick on WiRe, if you want to see the backside, tick also on 2-sided
If you want a combination, just copy the same object and apply another material as shown on the image below
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 4 of 9
Where do you find 'Shader and Basic Parameters'? In my version 3dsMax 2022,
it is not located, or doesn't show in my Material Editor:
Message 5 of 9
CiroCardoso3v
Change to Slate Material Editor, and then it will be easier to search for that node. Which renderer are you using?
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 6 of 9
Using Arnold and when I switch and search, I still can't seem to locate it.  Remember, I am a COMPLETE newbie at this...  Just need to do a wireframe render for an assignment and can't seem to find out how for version 2022.
Message 7 of 9
CiroCardoso3v
You have to type Wire
Ciro Cardoso
Message 8 of 9
Oh, that way.  Yeah. I have tried that method with mixed results.  Doesn't seem to want to render correctly.  I was hoping to find out how to use 'Shader and Basic Parameters' as that method seems easiest.  just can't seem to find it in 2022 version...
Message 9 of 9
CiroCardoso3v
That option appears on Blinn material, which isn't supported by Arnold. I can give you a hand with the Arnold bit. Can you share a reference of what you are trying to achieve, and how the wire node isn't giving you what you need?
Ciro Cardoso
