Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to create water material for Scanline Renderer?
travis.designer.vn
travis.designer.vn
Hi
I intent to use A360 Cloud Render. I need water material.
Best regards
Travis
Francisco_Penaloza
Water and an ocean or a pool are more than just a shader, you need to also deform the surface/Geometry and adjust the environment to make the water look the way you need.
I have created this tutorial time ago rendered with V Ray but the same principles can be used with any other render engine.
BTW the A360 could render works better with Physical materials and you can test it with Art render.
Francisco_Penaloza
I don't know why the forum is not showing the screen cast, here are the tutorials again.
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/de5d3d14-40f4-470d-81b2-205633c437ba" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
<iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/d2b942e2-e8a0-4719-bd8e-9327324b8278" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
