Hey Ted - welcome back from your travels!
I hadn't touched the Blur (Coordinates rollout of the Diffuse Map). Just tried lowering it to its minimum value (0.01) from its default (1.0) - it actually made the situation worse! Those edges show up much more clearly.
Applying a UVW Map (default settings) helps - the edges are much fainter, but they're still there.
All the rendering settings are at their defaults, no effects, the only changes I made were to the background colour (grey instead of black) and the Tint level (2 instead of 1).
Obviously a Checker pattern is a much more harsh test than a tree - and rendered up close at that. Probably a with a tree at some distance from the camera this wouldn't be an issue, but it's still something I'd like to get to the bottom of.
Thanks for the reply
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
