3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Different Colors Between Corona VFB and Saved Image
2 REPLIES 2
designproduto
421 Views, 2 Replies
Hope you guys are doing all right.
I'm using Max 2025 and Corona 12. In the Corona VFB, the render looks fine, but when I save it, the colors appear very different.
I tried changing the "OCIO - 3ds Max Default" to "Gamma Workflow 2.2" and while the saved render changes, it still remains different from what I see in the Corona VFB.
Can someone please help?
Thank you,
Eduardo
2 REPLIES 2
1. Check Color Space: Ensure consistent color space settings in the Corona VFB (set to sRGB).
2. Gamma Settings: Make sure gamma settings match (e.g., "Gamma Workflow 2.2").
3. Render Output Settings: Verify the output format and color space in the Render Setup.
4. VFB Post-Processing: Check for any post-processing effects applied in the VFB.
5. Test Different Formats: Save renders in various formats (like TIFF or PNG) to see if discrepancies persist.
6. External Color Profiles: Ensure no external color profiles are altering the output.
7. Render Elements: Verify that render elements are set up correctly.
8. Update Software: Keep both 3ds Max and Corona Renderer updated.
Enjoy your work.
VirtualView
in reply to: designproduto
Hey, was a solution found here?
I have the same problem and can't get any further...
Best regards
Jannik
