Hi @tonyinseattle,
Sorry for the delayed response! I downloaded your file but it's not opening, we may not have the same version of Arnold installed, I'm getting the error, Would you send me the file in a private message? maybe the zip file is cutting the download short or something.
Also, that's odd that the ground material isn't receiving any of your lighting, but its receiving your shadows, would you mind taking a screenshot of your material settings for the ground plan Shadow matte, and also showing me what angle your light is at? It looks like you have a really soft pink light that isn't effecting the ground plane much. Here is the documentation I could find on Arnold AOV's in 3DS Max. It looks like if you can set up the AOV for your light, you can see how it effects the ground plane, and adjust the lighting from there.
"Each light object has an AOV parameter which writes out the light contribution to a separate AOV with a corresponding name. Available per-light AOVs are displayed in the lists with the (light group) postfix once any of the lights have an AOV light group defined."
I went into my Arnold light settings and scrolled down to the bottom until I saw AOV, and I named it Light_1, I then went into my render settings, and added Light_1 into my custom AOV's and it appeared on my list of AOV's in my active renderer, so that's a step in the right direction...though it's still not rendering anything! Here are my settings so far.
I will continue poking around and I will eventually make sense of these settings. Sorry we haven't been able to figure this out right way, thanks for being patient 😄
