Adding a lot of dirt
balintka_varga
Observer Observer
balintka_varga
Observer
Observer
Hello dear colleagues,
I have this object on the image with a black texture.
I would like to add that high amount of yellowish-gray dust and dirt seen on the surfaces and in the corners.
I will have to render the whole thing as a texture and apply it later, since the model will be converted to a game.
I tried VrayDirt but it doesn't add that extensive dirt, and also tried to unwrap UVW, render to texture and just paint on it in Photoshop, but the polygons appear distant on the rendered map and the dirt is not seamless (there are edges staying in between).
The dirt can be of course much much more as seen on the image.
How would you do it?
You are kindly asked to keep the explanation simple, I'm not a professional modeler.
Thank you very much
Balint
RobH2
Do you have a subscription to Substance Painter? That would do it perfectly and generate the PBR maps for Max and it would look great. If this is a paying job it might even be worth doing Substance Painter for just one month, finish the job, get paid and then move on.
VrayDirt in combination with VrayDistanceTex might get you closer. But if you do a lot of texturing, Substance is good to have in your toolbag. It's really powerful.
Check this out:
https://www.youtube.com/watch?v=Ix4eknncFU0&t=349s
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
balintka_varga
Observer
Observer
Thank you, that just suits my needs, I'm going to dive into it. Many thanks again!
