3DSMAX 2018 "render setup" dialog not showing dialog
3DSMAX 2018 "render setup" not showing dialog. I have multi monitor and I've checked everything there. Even shut down to single monitor while I debug.
Other things I've tired with no success.
1. toggle to a different system UI. No success
2. I heard in the past renaming the 3dsmax.ini would reset the complete UI. Can't find it I'm guessing 2018 no longer uses it.
3. changed resolution to the max and slammed to single monitor
4. Render worked fine and other dialog boxes open fine
5. Tried different files , no difference
6. Did standard uninstall and then reinstalled the product. No difference. I thought that would have worked for sure. No success.
7. NVidia's management program shows full desktop in app as you move things from one screen or if it overlaps. It don't show in that diagnostic panel
Anyone got any Ideas, just want to change resolution of the output. lol Thanks in advance.
Kreaction
3dsmax.ini got dialog position
rename it from 3dsmaxfolder/en-us
or
maxini=getMAXIniFile()
setinisetting maxini "RenderDialogPosition" "Dimension" 0 0 0 0"
Thanks that was tremendous. I read that a few time for 2008 and nine and 10. I thought it might work but couldn't find the file. May need a button that says "Reset INI and Restart 3dsmax". I've seen this happen twice in 4 months. Thanks for answering. Just wonder why a full uninstall and reinstall didn't correct the situation? Thanks again
