3ds max crashes when parsing - Corona Renderer
Message 1 of 8
Any ideas? All worked well until a couple of days ago when it started crashing on random scenes a few seconds after I press the render button.
Replies (7)
Message 2 of 8
maciej.dziubinski6
Observer
Observer
I have there same problem with one scene, no matter what i'd erase or hide from scene it's crushing when rendering just in the very beggining of it.
Message 3 of 8
CiroCardoso3v
How complex are you scene? Corona isn't very good when you have complex scenes.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Message 4 of 8
maciej.dziubinski6
Observer
Observer
I got only 7 milion polys, i did already bigger ones there was not any
problem with that. No alerts of lack of RAM as well.
Message 5 of 8
CiroCardoso3v
Ok, couple of things you can try. First, try to merge everything into a new scene. I know it sounds ridicolous, but 7 out 10 solves the issue. Second, see if it renders with a material override. If so, could be an issue with one of your materials. I beleive Foresinc from SINI is free, and you could use that to clean your scene. For me an issue with Corona, is that you have no log from them to understand what is causing the issue. Althoug you can always check the  CoronaMax_log.txt somewhere in appdata folder, but isn't going to give you much.
Ciro Cardoso
Message 6 of 8
maciej.dziubinski6
Observer
Observer
I alreacy tried to merge the scene element by element to check what’s possibly wrong in the scene.
Message 7 of 8
CiroCardoso3v
I believe then you will have to check with their support. Have you checked the log that I mentioned?
Ciro Cardoso
Message 8 of 8
maciej.dziubinski6
Observer
Observer
Hello, thank you for your support, somehow it started to work by itself,
with no reason just like it crashed.
Recuerdos
