I cannot save an image from the Render output window. For what I do I often need a basic image of my geometry for creating masks. It's worked fine for years. I also tried assigning a Render Output path and I get an error.
What renderer are you using, or is it with all of them? What is the exact error text?
I went through it again, so unless i'm missing something... I can copy from that dialog onto the clipboard and paste it into photoshop.
I'm not having same issue with 2017. Judging from that error I can't help but think this may be a folder permissions or drive issue. Can you save to another location? Also see if it continues to fail if you try to save to another drive or even a USB key.
Hello @bthatcher,
This might be an odd question, but is that a valid path? Meaning, was it created in an older file and now that user doesn't exist with that same exact name/path?
What happens if you repath it to a folder somewhere on C: instead of your desktop, does it work then? You may not have the permissions to write for your desktop, which is odd but seems possible. Thanks for the extra details.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I found the problem, my computer was unplugged! Ha, kidding. Thank you for your reply, I guess that's possible. A little more testing revealed that I could save to .jpg or .bmp, but not .png. Also, I was using the default ART renderer. When I switched to Scanline, I could save to .png. I've not explored the ART renderer to any length. Can someone test that? Thanks.
HI,
I can, and often do, save as .png from the RFW when using the ART Renderer. Just tested again to be sure. No problems here.
Hello @bthatcher,
My experience was the same as @Daf's here. Which service pack are you currently running? I don't see any currently existing bug tracker cases for Art and saving .PNG files, but if this is reproducible I'd be happy to log it. Does this happen with all files or just the current one? What happens if you try to save it to a different place like C: root or your desktop?
Best Regards,
Hello @bthatcher,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Thanks for checking back. I don't know, just a fluke I guess. Consider it resolved.
Hello @bthatcher, thanks for the update.
Is it happening with all files or just the one? If this persists or the problem evolves, please let me know. I don't want to just give up on ya, but I understand if you'd prefer to move on. I can create a private folder if you want me to check the file.
I'll be out of office for the next 5 days so you don't have to respond unless you want to, but I'll happily work on this if you'd like for as long as you'd like.
Best Regards,
I am having the exact same issue, suddenly last night. Also with .png files. I am unable to save from the render window, from a clone window, or to a save location specified in the render dialog, or to a location in the render elements dialog. I was attempting to save a shadow only frame, so had specified a render elements, shadow save location and that's when the save trouble started. I did a full render the day before to .tga fine. I tried different drives and folders to no avail. I got the same dialog box that said Max was unable to save the .png file.
I am rebooting now to try again, seeing if it does happen whether it works to change to tiff format. I will update the result here. If it is still broken I will post my system config. If it suddenly works again I will mention that.
OK, I rebooted computer and tried again, loading a different Max file. I find that I am able to save a .png file as long as it is 24 or 48 bit, and it can be with or without alpha. Max is failing to save, either from the render window or the render dialog box save location, a greyscale 8 or 16 bit file, doesn't matter if it is with or without an alpha. So this seems to be for me at this time a greyscale .png only problem. I can save an 8-bit greyscale tiff file, no problem, but there is no other greyscale 16-bit save format, so the file I want to save I just can't. I believe I have the latest software config for 2017, as it has SP3. I am unable to install Windows 10 on this workstation due to an incompatibilty with the motherboard.
Max: version 19.0 sp3 commercial (2017)
workstation: Lightbeam E5 16200
proc: Intel Xeon E5-2650 (2) @ 2.00GHz
mem: 64GB
OS: Win 7 Pro 64-bit
