Hello I have a script that will insert XYZ coordinates with yaw, pitch and roll.
The Script grabs the cell data and inserts a Point at a given Time, then with Animate On, it transform the point to the cells Data.
2 Issues i'm having with the Script.
1st I have fractions of a seconds increment that is needed. The Time is Multiplied by 30 FPS. the Results is a decimal frame in many cases, so I have it rounding down to the whole frame. Can you Code Time in Sub-Frame Format, like at Frame 22.75 have a keyframe. (I know I can display Frames:Ticks to scrub the timeline in subframes.) Can that be coded? if so please share.
The other Issue is that my X,Y, Z values are not landing on the exact number that's represented in the excel file, but the rotational values are fine.
For instance Row 7 xyz is returning -600.04, 56.888, 31.24. I'm wondering if Max retains variables in memory, and this causes a shift in the results.
WHy wouldn't the World XYZ values work? I have no shifting in the code.
THe xyz values are multiplied by 12 for Inch unit Scene.
theDummy.pos = [(BPrefixdStrings*12), (CPrefixdStrings*-12), (DPrefixdStrings*-12)]
THe excel and Script is attached. Please share solutions and suggestions.
-- Start an Excel OLE Object -- USE SCENE SET TO INCHES units. Open Listener for reported values. x = CreateOLEObject "Excel.Application" -- Create a new workbook in the new excel document ----x.Workbooks.Add x.Workbooks.Open("C:\Motion.xls") -- This makes Excel Visible --x.visible = true --x.Rows.Count --x.application.Cells("A1").Value (x.application.Range("A1")).value theDummy = Point showtrajectory:true --create a helper with trajectory on TheDummy.size = 400 counter = 3 while counter < 12 do --while counter != "undefined" do ( counter = counter as String --print counter --COLUMN A cellValueA = (x.Range("A" + counter )).value as String OldStringA = "d0" NewStringA = "" APrefixdStrings = replace cellValueA (findstring cellValueA OldStringA) OldStringA.count NewStringA --COLUMN B cellValueB = (x.Range("B" + counter )).value as String OldStringB = "d0" NewStringB = "" BPrefixdStrings = replace cellValueB (findstring cellValueB OldStringB) OldStringB.count NewStringB --COLUMN C cellValueC = (x.Range("C" + counter )).value as String OldStringC = "d0" NewStringC = "" CPrefixdStrings = replace cellValueC (findstring cellValueC OldStringC) OldStringC.count NewStringC --COLUMN D cellValueD = (x.Range("D" + counter )).value as String OldStringD = "d0" NewStringD = "" DPrefixdStrings = replace cellValueD (findstring cellValueD OldStringD) OldStringD.count NewStringD --COLUMN E cellValueE = (x.Range("E" + counter )).value as String OldStringE = "d0" NewStringE = "" EPrefixdStrings = replace cellValueE (findstring cellValueE OldStringE) OldStringE.count NewStringE --COLUMN F cellValueF = (x.Range("F" + counter )).value as String OldStringF = "d0" NewStringF = "" FPrefixdStrings = replace cellValueF (findstring cellValueF OldStringF) OldStringF.count NewStringF --COLUMN G cellValueG = (x.Range("G" + counter )).value as String OldStringG = "d0" NewStringG = "" GPrefixdStrings = replace cellValueG (findstring cellValueG OldStringG) OldStringG.count NewStringG --print APrefixdStrings print " -- " theTIME = APrefixdStrings as Float --theTIME = floor ((theTIME)*30 + 0.5) theTIME = floor ((theTIME)* 30) print counter print theTIME print BPrefixdStrings print CPrefixdStrings print DPrefixdStrings BPrefixdStrings = BPrefixdStrings as Float CPrefixdStrings = CPrefixdStrings as Float DPrefixdStrings = DPrefixdStrings as Float EPrefixdStrings = EPrefixdStrings as Float FPrefixdStrings = FPrefixdStrings as Float GPrefixdStrings = GPrefixdStrings as Float print EPrefixdStrings print FPrefixdStrings print GPrefixdStrings with animate on --enable autokey animation context ( at time theTIME --set the current time for the following expression --for Scene set to "inches" units, multiple values by 12. theDummy.pos = [(BPrefixdStrings*12), (CPrefixdStrings*-12), (DPrefixdStrings*-12)] --place dummy at 1st coord. print theDummy.pos at time theTIME move theDummy [BPrefixdStrings, CPrefixdStrings, DPrefixdStrings] --moves dummy subsequent values in excel. --Rotates the Dummy just fine at time theTIME theDummy.rotation.x_rotation = EPrefixdStrings at time theTIME theDummy.rotation.y_rotation = FPrefixdStrings at time theTIME theDummy.rotation.z_rotation = GPrefixdStrings )--End With --print APrefixdStrings --print trimValue counter = counter as Integer counter = counter + 1 )--End while counter = counter as Integer counter = counter - 1 print "Last Row " + counter as String -- Change the color of A1:B1 to red --(x.application.Range("A1:B1")).Interior.ColorIndex = 45 -- Save the spreadsheet --x.application.ActiveWorkbook.SaveAs(excelFile) -- Close the spreadsheet x.application.ActiveWorkbook.Close -- quit excel x.quit() -- Release the OLE Object releaseOLEObject x -- Release ALL OLE Objects, just incase releaseAllOLEObjects()
Solved by freedom1k. Go to Solution.
Actually, I found my errors. I had a second move command that overwrote the 1st, thus driving me crazy. 🙂
Also, this answered my question about subframes. Ticks!!
Thanks for posting. This helped me, too.
I am trying the script but I have some issues (I have no experience in max scripting)
1. I do not understand what is the "second move command" and therefore I get the double number of X Y Z values.
2. I cannot make it work for more than 11 rows of excel data
Does anyone have a final script to share?
Thank you in advance
Hello.
You have to modify the script to fit your data. change line where it says <12 to fit the lines of Data Rows in your file.
Change counter = 3 to where your data starts. so if you have unrelated info above Row 3 in Excel, it will be ignored.
I think you also must not have excel open during run-time.
