3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Write Max plugins with VC++ 2010 Express...
1 REPLY 1
PhilHook
771 Views, 1 Reply
Hi all...  (Apologies for the lengthy post!)
I'm trying to get setup with VC++ 2010 Express to develop plugins for Max - or at least start learning the process...  I've got extensive Maxscript experience, along with a number of other scripting languages, but no C++ experience, so I'm a total Noob when it comes to plugins!
After 2 days spent tinkering I've hit a roadblock I can't Google my way out of!... I'm sure there are others out there in the same bind - hopefully someone has some answers!
My setup is as follows...  (following the specs outlined here)
Windows 7 Home Premium 64bit
3ds Max 2013 64-bit
3ds Max SDK 2013
Direct X SDK (June 2010)
(http://www.microsoft.com/en-au/download/details.aspx?id=6812)
-- Needs to be installed before V C++ 2010 because of conflicts explained here
Visual C++ 2010 Express
(http://www.visualstudio.com/en-us/downloads#d-2010-express)
VS 2010 Service Pack 1
(http://www.microsoft.com/en-au/download/details.aspx?id=23691)
VS 2010 Compiler Update (KB2519277)
(http://www.microsoft.com/en-au/download/details.aspx?id=4422)
-- Needs to be installed to fix errors caused by the SP1 installation
Windows SDK for Windows 7 and .NET Framework 4
(http://www.microsoft.com/en-au/download/details.aspx?id=8279)
Once all were installed successfully, I followed the Plugin Wizard setup instructions...
The Wizard seems to work fine - it generates all the files outlined in the help doc (for a Utility plugin at least)...
In the Project Properties, I then do the following...
- Set Configuration as 'HybridUnicode'
- Set the Platform as 'x64'
In user32.lib VC++ Directories > Include Directories I add : $(ADSK_3DSMAX_SDK_2013)include
In Configuration Properties > VC++ Directories > Library Directories I add : $(ADSK_3DSMAX_SDK_2013)x64\lib
In testProj.rc I comment out #include "afxres.h" (as it causes fatal error RC1015) and add #include "WinResrc.h" and #define IDC_STATIC -1
When I build, I get this error...
C:\Program Files\Microsoft SDKs\Windows\v7.1\lib\x64\user32.lib : fatal error LNK1107: invalid or corrupt file: cannot read at 0x22C38
I notice that user32.lib appears in list of Inherited values under Configuration Properties > Linker > Input > Additional Dependencies...  I tried building with inherit disabled, but I just get a different error...
Any help - any at all - would be very much appreciated...
Cheers
1 REPLY 1
akira.kudo
in reply to: PhilHook
Hi
I am sorry for delay.
I had been trying to build same environment from scratch. (installing windows, VS and etc...) Unfortunately I am hitting another problem below now. Bulding plugin with x86 works fine, but not for x64 due to missing the "ConfigurationGeneral" rule as below.
1>Error: The "ConfigurationGeneral" rule is missing from the project.
From the matrix below, it seems that the Express does not support 64-bit x64 compiler.
http://msdn.microsoft.com/en-us/library/hs24szh9.aspx
So can you try to install another VisualStudio, not Express?
Akira Kudo
Developer Technical Services
Autodesk Developer Network
