Visual Studio Cannot Find "dllentry.cpp"
xxshirzadxx
Message 1 of 9
xxshirzadxx
As a scripter, I'm trying to make my first plugin using app wizard in visual studio.
I did everything as mentioned in "readme.txt" and I still get this error.
Here is the information you may need for helping me:
  • My SDK Path: "D:\program files\Autodesk\3ds Max 2022 SDK\maxsdk"
  • My Visual Studio Version: "2022"
  • My ".vsz .vsdir .ico" File Path: "C:\Program Files\Microsoft Visual Studio\2022\Community\Common7\IDE\VC\vcprojects"
  • My "3dsmaxPluginWizard.vsz" Text File:
VSWIZARD 7.0
Wizard=VsWizard.VsWizardEngine.17.0
Param="WIZARD_NAME = 3dsmaxPluginWizard"
Param="ABSOLUTE_PATH = D:\program files\Autodesk\3ds Max 2022 SDK\maxsdk\howto\3dsmaxPluginWizard"
Param="FALLBACK_LCID = 1033"
My problem is that 'dllentry.cpp' is exactly on that path and it can not be found!
Replies (8)
Message 2 of 9
istan
https://help.autodesk.com/view/MAXDEV/2022/ENU/?guid=Max_Developer_Help_about_the_3ds_max_sdk_sdk_re...
I would not be totally sure, that VS2022 is supported already..
Message 3 of 9
xxshirzadxx
It does actually.
I compiled some samples with it.
Only appWizard have this problem.
Message 4 of 9
istan
Compilation is one thing but the wizard is a different story. AFAIR in older Max versions the wizard needed to be tuned to get it working with newer VS releases.
Message 5 of 9
xxshirzadxx
Sure, but I had the same issue with VS 2019
Message 6 of 9
istan
2022 (24.0)Windows 10 x642022Microsoft Visual Studio 2017, Platform Toolset v141, Windows SDK 10.0.17134.0.NET 4.8Qt 5.15.1
Message 7 of 9
xxshirzadxx
Just tested out 2017, still have the same error.
Message 8 of 9
istan
Then I'm running out of ideas.
You could download the SDK from Max2020 and test this Wizard with VS2017.
If it's working with the paths from Max2020SDK, you just have to change the include/library paths to point to Max2022SDK in order to build plugins for Max2022.
Message 9 of 9
Serejah
You have installed sdk on disk that is different from C: so it might be the issue.
Check if environment variables are set to correct sdk path.
And maybe you need to edit paths in 'C:\Program Files\Autodesk\3ds Max 2014 SDK\howto\3dsmaxPluginWizard\HTML\1033\userDefaults.js'
