Trouble using filterstring to get folder name from file path
10DSpace
Advisor Advisor
10DSpace
I am getting an error message with the following lines of maxscript and I am hoping someone here can tell me what I am doing wrong:
fdir = GetSavePath caption: "Select Directory for Export" initialDir:(maxFilePath)
--Now store the folder name to use as the name of the combined .fbx
thefolder = filterstring fdir “\”
thefolderName = thefolder[thefolder.count]
The error message is :
-- Type error: FilterString [String to filter] [Tokens] requires String, got: undefined
-- MAXScript callstack:
-- thread data: threadID:12784
-- [stack level: 0]
-- In top-level
-- Error occurred in anonymous codeblock; filename: C:\Users\Dave\AppData\Local\Autodesk\3dsmax\2020 - 64bit\ENU\usermacros\ExportMultipleObjectsforSP.ms; position: 992; line: 26
-- Syntax error: at bad, expected <factor>
-- In line: thefolder = filterstring fdir “\”
The GetSavePath function works fine and I verified that fdir is in fact storing the file path I select.
I tried adding an extra "\" (i.e.,  "\\")  in case an escape character is required, but that did not work. Same error message.  I tried to set another variable called folder_string to make sure it is a character string as follows:
folder_string = fdir as string
and then use that variable in the filterstring  line.   Again it had no effect.  Same error message.
Any guidance would be greatly appreciated.
ads_royje
Hi @10DSpace ,
indeed, it should take the double backslash as backslash is an escape character.
coping your code string I get the same error. Seems to be related to the double quotes ...
Max does seem to like these
and prefer these
can you tell me if this one works for you ?
fdir = @"C:\fold_1\fold_2\fold_3\fold_5\fold_6\"
thefolder = filterstring fdir "\\"
10DSpace
@ads_royje
Thanks very much! All I did was copy the preferred double quote to my line of code and added back the escape for the "\" and it worked perfectly.  I guess I picked up a strange double quote by cutting and pasting that particular line from a code snippet I found at polycount I think.  I am pretty sure that I would not have noticed the different double quotes character in this lifetime, so you saved me lots of time!
ads_royje
Great to read ! 🙂
Thank you for your feedback!
