TextPlus: How to label an Object using its Object name
Message 1 of 10
Is it possible to label an Object with its Object Name using TextPlus?
I have watched the TextPlus Set Value as Text tutorial but this only enables values from a reference Object, not its Name
I have ~200 objects to label in my scene, it would be much quicker if there is a method to support this, rather than having to type out the individual object names 200 times
thanks
Replies (9)
Message 2 of 10
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
Since this thread didn't get a reply and I'm not really great at scripting I am going to move this thread to the programming forum in the hopes that you get a reply there.  Thank you.
Best Regards,
Message 3 of 10
no worries @Alfred.DeFlaminis, cheers
Message 4 of 10
drew_avis
Hi, here's a short script that applies a textplus label to every non-textplus object in a scene.  You can use it as a starting point for what you're trying to do.
-- label everything in the scene w/ a textplus
fn label_it obj = (
	str = obj.name
	t = TextPlus size:10
	t.SetFont "Arial" 0
	t.ResetStyle()
	t.ResetString()
	t.AppendString str
	t.pos = obj.pos
	bb = nodeLocalBoundingBox obj
	t.pos.z = bb[2].z
allObjects = $*
for obj in allObjects do (
	print obj.name
	-- don't label textplus objects, that would be silly
	if (classOf obj != TextPlus) do (
		label_it obj
Drew Avis
Content Experience Designer
Message 5 of 10
Alfred.DeFlaminis
Nice one Drew, I tested it and it's great!  Does that help @Anonymous?
If you feel that this solves the issue for you @Anonymous, please mark Drew's post as the solution.  Thanks!
Best Regards,
Message 6 of 10
cheers thanks @drew_avis exactly what I was after!
Message 7 of 10
thanks @Alfred.DeFlaminis for progressing this, as always you rock
Message 8 of 10
nice @drew_avis, if you don't mind, I think this is useful (just 1 bold line added)
fn label_it obj = (
	str = obj.name
	t.SetFont "Arial" 0
	t.ResetStyle()
	t.ResetString()
	t.AppendString str
	t.pos = obj.pos
	t.pos.z = bb[2].z
	t.parent = obj   -- link label to object
allObjects = $*
	print obj.name
		label_it obj
just so if you move the objects around, the labels go with them...
Message 9 of 10
drew_avis
@Anonymous, good addition - you could also put the labels on their own layer to easily show/hide.  Lots of potential for fun with this one.
Drew Avis
Message 10 of 10
Alfred.DeFlaminis
Happy to do whatever I can @Anonymous. Smiley Very Happy  Thanks for the kind words.   Good idea here @Anonymous and thank you very much @drew_avis for your awesome code.
I made a small addition as well, adding a tiny bit of extrude to the lettering so when zoomed out the faces don't overlap.  (Default setting of textplus.)
fn label_it obj = (
	str = obj.name
	t.SetFont "Arial" 0
	t.ResetStyle()
	t.ResetString()
	t.AppendString str
	t.pos = obj.pos
	t.pos.z = bb[2].z
        t.extrudeamount = 0.025
allObjects = $*
	print obj.name
		label_it obj
Best Regards,
