STL batch export script help!
Message 1 of 15
I need to get hold of a script that will batch export my geometry to individual STL files and set the individual STL file names to the same as the internal max object names.
The STLs need to be in ASCII format
I.e in my scene i have an object named BOX1 and one named BOX2
I want the option to export them individually or in a batch
I want BOX1 to create an STL with the name BOX1.STL etc etc
I have approx 700 objects in the scene and i want an individual STL for each
As i want to export a large number of files i dont want any prompts etc.
I would quite like to just have a box in the menu bar that i could click on an object or a collection of objects and click export and hav them all sent to a specific folder.
Any clue?
I am new to MAX script so this is probably an ambitious project to start with... HELP 🙂 !!
Anyone done anything similar that i could modify?
Replies (14)
Message 2 of 15
maybe this is you need
Message 3 of 15
Steve_Curley
Unfortunately that doesn't address the requirement for an STL export, as stated in the thread title / topic, neither does it address the reqirement for exporting each object to its own file named appropriately.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 4 of 15
I think he was suggesting that you could write the ASCII data 'manually' instead of relying on the exporter. The format of STL itself is pretty simple, although the code required to generate solid data from mesh data probably isn't.
It's not an optimal solution, but I suppose it would serve if no better way turns up.
Message 5 of 15
Steve_Curley
Thing is - there is already a way to do it - the "exportFile" function, but I can't get it working for STL files - see this thread. The rest of it - iterating over a selection, generating the right filename and so on is pretty straightforward, but I don't fancy reinventing that particular wheel when one already exists.
Max 2016 (SP1/EXT1)
Message 6 of 15
Steve_Curley
Ok, here's your solution (I think 😉 ).
macroScript Export_Selected_2_STL category:"ScrewyScripts" tooltip:"Export selected to .STL"
global STL_Object_Name = ""
fn SetSTLExportOptions =
local BM_GETSTATE = 0xF2
local BM_CLICK = 0xF5
local BM_SETCHECK = 0xF1
local BST_CHECKED = 0x1
WindowHandle = DialogMonitorOPS.GetWindowHandle()
if ((UIAccessor.GetWindowText WindowHandle) == "Export STL File") then
children = UIAccessor.GetChildWindows WindowHandle
for i = 1 to children.count do
child = children
childTitle = (UIAccessor.GetWindowText child)
if (childTitle == "Object01") then
UIAccessor.SetWindowText child STL_Object_Name
if (childTitle == "Selected only") then
cbState = windows.sendMessage child BM_GETSTATE 0 0
checked = bit.get cbState BST_CHECKED
if (checked == false) then
windows.sendMessage child BM_CLICK 0 0
windows.sendMessage child BM_SETCHECK 1 0
uiAccessor.sendMessageID WindowHandle #IDOK
true
DialogMonitorOPS.unRegisterNotification id:#Set_STL_Export_Options
DialogMonitorOPS.RegisterNotification SetSTLExportOptions id:#Set_STL_Export_Options
DialogMonitorOPS.Enabled = true
selected = for obj in selection collect obj
for obj in selected do
STL_Object_Name = obj.name
select obj
exportFile ((getDir #export) + "/" + STL_Object_Name + ".stl")
DialogMonitorOPS.Enabled = false
Max 2016 (SP1/EXT1)
Message 7 of 15
Tanks for That, but i am having trouble getting that last script to run
When i try to launch it from Max 2009 nothing happens
This is the Code sampe i have been using in the past, The problem is that it launches the internal STL export window without copying over the object name.
It can be used for multiple files, but is a bit buggy and due to the large number of files to export, it is a pain having to manually rename the internal STL names to match those in max.
--this script is made by Anton Berg at os3d.se
--antonos3d.se
rollout ExportObj "Export as separate files" width:232 height:107
global theClasses
global outPath
local debug = true
edittext edt1 "filename" pos: width:152 height:16 readOnly:false
button btn1 "Export" pos: width:56 height:40
checkbox chk1 "Prefix of the file:" pos: width:120 height:16 checked:true toolTip:"if this is checked then the prefix text will be used to name the file"
dropdownList ddl2 "FileType" pos: width:152 height:40
checkbox chk2 "Debug" pos: width:56 height:16 checked:true tooltip:"This will show error messages"
fn NewfileName inputPath objName ischecked nr= (
if ischecked == true then
--set the filename to this prefix
np = inputPath + "\\" + objName + "_"+ nr as string --+".obj"
if debug then print np
else
--set the filename to the object filename
np = inputPath + "\\" + objName --e+ ".obj"
return np
on ExportObj open do
theClasses = exporterPlugin.classes
theClassesNames = #()
for exptyp in theClasses do
append theClassesNames (exptyp as string)
ddl2.items = theClassesNames
on btn1 pressed do
if outPath == undefined then outPath = ""
outPath = getSavePath initialDir:outpath
if outPath != undefined then
selArray = selection as array
sceneObjs =#()
for item in selArray do
try (explodeGroup item)
catch()
if (isKindOf item GeometryClass) then append sceneObjs item
for i = 1 to sceneObjs.count do
oname = (if chk1.state then edt1.text else sceneObjs.name)
if i == 1 then
select sceneObjs
newName = NewfileName outPath oname chk1.state i
result = (exportFile newName using:(theClasses) selectedOnly: true)
if result != true then (
if chk2.state == true then (messageBox "OS3D debug INFO:\nYou have a selected a filformat that doesn´t except the selected only state..")
result = (exportFile newName using:(theClasses) selectedOnly: false)
if i > 1 then
select sceneObjs
result = (exportFile newName #noPrompt using:(theClasses) selectedOnly: true)
--messageBox "You have a selected a filformat that doesn´t except the selected only state.."
select sceneObjs
else
messagebox "No output path selected"
on chk1 changed theState do
if theState then edt1.readOnly = false else edt1.readOnly = true
createdialog ExportObj
Message 8 of 15
Steve_Curley
Remove the 1st line (that's outside the parenthesis) - quite why it doesn't like that I'm not sure, but it definitely works if you do that. Obviously "evaluating" a script in the editor isn't quite the same as Running a script.
Note. it expects the objects to be selected prior to running the script - and there's no error trapping to tell you if you haven't !
Just realised you want the output in ASCII format - I'll have a look at changing it to do that
Modified script attached
19298_p5gHAlgoqDmtRcDQvNgW.zip
Max 2016 (SP1/EXT1)
Message 9 of 15
Perfect! That is exactly what i neeeded THANKS!
Message 10 of 15
Steve_Curley
I knew we'd get there eventually 😉
Max 2016 (SP1/EXT1)
Message 11 of 15
Hi, this is a great script but only works in max 9, is there a way of getting sorted in max 8?
Cheers for the help guys, pulling my hair out here.
Message 12 of 15
Steve_Curley
I'm afraid not. The UIAccessor and DialogMonitorOPS functions were introduced in Max 9 - they simply don't exist in Max 8.
The ExporterPlugin.classes and exportFile are there and work, the problem is accessing the UI elements in order to enable "Selected only" - that's the bit which doesn't exist in Max 8
Max 2016 (SP1/EXT1)
Message 13 of 15
spencer.fitch
Is there anyway I can get this script still? This is exactly what we need for a big project. Max 2021
Message 14 of 15
mdoone03
Observer
Observer
Hey, did you ever solve this? Crazy old thread but very important topic and cant find anything else online with more recent MAX versions.
Message 15 of 15
denisT.MaxDoctor
It's better to start a new topic and explain your needs and problems in detail, rather than reviving an old one.
