Simple Popup Message Box Macro Script (error!)
utku.demirZFGQ5
utku.demirZFGQ5
Hello Dear All,
I'm pretty rookie about Max scripting (trying to learn) so simple I wish to script that: if object/s not selected > show message box or if something currently selected give that amounts for uvw!
I tried as you can see here:
But I'm getting that error:
How can I solve this?
Best Regards
Here code itself:
macroScript Macro5
category:"DragAndDrop"
toolTip:""
if selection.count == 0 then messagebox "please select an object first!" title:""
else
modPanel.addModToSelection (Uvwmap ()) ui:on
$.modifiers[#UVW_Map].utile = 20
$.modifiers[#UVW_Map].vtile = 20
$.modifiers[#UVW_Map].wtile = 20
a2d4f3s1
In this case, you can write it like this:
macroScript Macro5
toolTip:""
	) else (
utku.demirZFGQ5
Thank you very much @a2d4f3s1, script working well now, for the sake of learning that bracket )()) logic (Syntax Definitions) I will check MaxScript Help website from Autodesk!
