Runtime error R6025 Pure Virtual Function Call - Microsoft Visual C++
Everytime I shut down my 3ds max 2016, a runtime error window pop out.
Microsoft visual C++ Runtime library
R6025 - pure virtual function call.
Is anyone know what I have done something wrong?
Thank you very much
Nelson Wong
I've same problem with Fusion 360 and I see (here), in 6 years no answer... OKay 😞
denisT.MaxDoctor
when you get this error message the system tells where it happened ... give us a screenshot of the message box
denisT.MaxDoctor
This usually happens when a system component (eg a plugin) no longer meets the "requirements". The solution is always to update or replace some component of the system (driver, library, compiler, etc.). But to come up with a fix strategy, we need to know where the problem was found.
Google translated 😉
Because I kept making mistakes and many things didn't work (e.g. nothing worked as soon as a second sketch
was created, the timeline was not "cleaned up" with a new component, no chance to insert STL objects, and
the error messages when closing Fusion 360) , I thought it was because of my CPU and RAM.
So I put together a new PC with 32GB RAM, an AMD Ryzen9 3900, Nvidia GTX 1080 with 11GB, Samsung 980 Pro M2
etc.
Then I installed Win10Pro with all the original drivers and at first only installed Fusion 360 and yes, the
other errors were all gone, but the error when closing Fusion 360 persisted. Without any plugins or anything
else.
